skelator
cura profiles -> s3d profiles
I'm trying to translate the cura option from https://3dverkstan.se/protective-visor/ ... int-guide/ to the closest s3d setting, I never used cura before so I'm have no cluse where to start, can anyone help?
Thanks!
S3D-Alex
Re: cura profiles -> s3d profiles
Could you let me know what settings specifically you need assistance with? It looks like they are recommending you edit the Infill %, Layer Height, Extrusion Width and some of the Print Speeds. Which of these were you having issues with?
skelator
S3D-Alex wrote: Tue Apr 14, 2020 10:49 am Could you let me know what settings specifically you need assistance with? It looks like they are recommending you edit the Infill %, Layer Height, Extrusion Width and some of the Print Speeds. Which of these were you having issues with?
Hi Alex,
I'm looking for the same setting for these
This means that the optimal line width is:
0.4mm nozzle -> Set line width to 0.5mm
0.6mm nozzle -> Set line width to 0.66 or 0.8mm
0.8 mm nozzle -> Set line width to 0.8mm or 1.0mm
1.0mm nozzle -> Set line width to 1.0mm
1.2mm nozzle -> Set line width to 1.33mm
how do we achieve this in s3d I can only find how set layer height, ultimately how do I configure s3d to use different layer height/width example below
0.8 line witdth
0.3 layer height
Thanks!
BrainMcFly
set in "Extruder " Extrusion witdth to "manual" and set it to 0.8 mm (Its line width, but line is in s3d called extrusion ;) )
in "Layer" set layer height to 0.3mm
