domiwettstein
Keep Factory Filename for save
Allready existing factory file is saved with the name of the first objects name, instead of the opened filename.
Request: Save factory file with CTRL-S should allways use the same name as opened.
Re: Keep Factory Filename for save
I believe this depends on how the factory file was opened. If it was automatically opened by the software (like in the case of you re-opening the software) the model's name is used. If you goto Load factory file, then the Ctrl + S option does save the factory file with the same name as the loaded factory file.
domiwettstein
S3D keeps the the folder Location in mind, wehre the last Project was opened instead of the origin path and filename.
