This has not yet happen when printer had a fresh boot up, only when printing from SD card second time, or third time.
Has anyone seen this? Is it wrong with firmware, printer, SD-card or simplify 3D? I´m using the exact same default starting g-code as replicatorG created for me (Replicator 1 dual printer).
I´ve not seen this with prints created in RepG but have not printed that much to say that it never happens
Starting G-code:
(**** start.gcode for The Replicator
dual head ****)
M103 (disable RPM)
M73 P0 (enable build progress)
G21 (set units to mm)
G90 (set positioning to absolute)
(**** begin homing ****)
G162 X Y F2500 (home XY axes maximum)
G161 Z F1100 (home Z axis minimum)
G92 Z-5 (set Z to -5)
G1 Z0.0 (move Z to "0")
G161 Z F100 (home Z axis minimum)
M132 X Y Z A B (Recall stored home offsets for XYZAB axis)
(**** end homing ****)
G1 X-110.5 Y-72 Z50 F3300.0 (move to waiting position)
G130 X20 Y20 A20 B20 (Lower stepper Vrefs while heating)
M6 T0 (wait for toolhead
and HBP to reach temperature)
G130 X127 Y127 A127 B127 (Set Stepper motor Vref to defaults)
M108 T0
G0 X-110.5 Y-72 (Position Nozzle)
G0 Z0.2 (Position Height)
G92 E0 (Set E to 0)
G1 E4 F500 (Extrude 4mm of filament)
G92 E0 (Set E to 0 again)
(**** end of start.gcode ****)
