Hopefully someone here can help me with a small problem. I can't seem to find the fix for this. When I try to print some things, the outside is perfect, and parts of the inside are perfect while other parts of the inside are a mess. Here is the STL I am trying to print, as well as a couple of photos (can't add photo of the other side, but it is perfectly printed). I am also adding my profile.
You can see in this photo how parts on each side are fine while the middle is a mess.
Can anyone please help? I bought S3D over a year ago and if I can't fix this I am switching back to Cura, because I have had enough.
(Same problem on 3 different printers so it is not a hardware problem)
Thanks for even reading this post.
