sinabu wrote: ↑Fri Jun 26, 2020 11:29 am
Quality setting with Supports, I tried default settings and also tried lowering the Support Pillar Resolution and tried 1mm and 2mm
and Angle but I am not able to get any supports to show up for this model. Help please!
looks like you've posted on Cults3D but forgot to mention this issue here:
"unable to get it to generate supports and the model looks corrupted and missing chunks of the model. "
If there's problems with the model file this might cause the problems with support generation. Sadly this is a paid model,
so posting the factory file would probably violate license terms....
Cults3D is suffering heavy load currently, timeouts everywhere. Wonder if that's caused by the giant star wars ship posted
there recently... xD
If you'd like to you can take another object to test for support generation. I've posted a cleaned up model on Cults3D a while
ago:
https://cults3d.com/en/3d-model/art/ali ... post-fixed
Try the head or boots, see if support generation does it's job there. Or go ahead and check the bought model file using NetFabb
for errors.
