tienbu
Speed changes and effects my print
Hi guys I am pretty new to simplify 3d. I am working on a prototype and I noticed a change of speed in the upper part of the design is effecting my print. Do you have any suggestion how to fix this issue.
zemlin
Re: Speed changes and effects my print
Uncheck that box. Could create other issues due to overheating. Might need to leave it checked and adjust the settings.
There's a similar setting under COOLING which you can also look at. I have had to add points under the temperature settings to reduce the temperature when features get smaller as well.
In the Speeds tab there is an option to have Simplify3D automatically slow down your print based on if the calculated layer time is below a certain threshold. Decreasing this threshold or unchecking the setting will remove this dynamic speed you're seeing in your preview.
tienbu
Wow thanks guys for the super quick response I will check it out.
