Hi guys I am pretty new to simplify 3d. I am working on a prototype and I noticed a change of speed in the upper part of the design is effecting my print. Do you have any suggestion how to fix this issue.
Uncheck that box. Could create other issues due to overheating. Might need to leave it checked and adjust the settings.
There's a similar setting under COOLING which you can also look at. I have had to add points under the temperature settings to reduce the temperature when features get smaller as well.
In the Speeds tab there is an option to have Simplify3D automatically slow down your print based on if the calculated layer time is below a certain threshold. Decreasing this threshold or unchecking the setting will remove this dynamic speed you're seeing in your preview.
