MEHDI3D
Slicing problem
Hello,
I'm a new user of your software.
When i try to prepare a part for printing I import the part (doesnt need suports) then i clic on "Prepare to print" buton. But the result that i got is only 3 layers ...
Can you help me please to resolve this problem?
Thank you.
Re: Slicing problem
Have a look to tab ADVANCED, perhaps there is set a stop.
GER
otherwise please attache a " *.factory " - file here.
To be create with tab FILE >>> Save Factory as ...
MEHDI3D
Re: Slicing problem
Thank you for your reply. Please find attached the .factory file.
V29D_Fixed.factory
(999.56 KiB) Downloaded 330 times
Re: Slicing problem
Cant find any problems, is running fine for me.
Your settings are not optimized but that is not the problem .
Perhaps you have used the Cross Section View and the Z-height was limited.
H.
