Hi all,
I have been very happy with Simplify 3d so far, and this is my first post on this forum( normally the articles and posts are sufficient) but I could not find anything helpful and I suspect this is an actual bug.
I have been printing/attempting to tune Benchy with PETG today, and I had a major reproducible issue with the chimney.
The Chimney seems to massively over-extrude on the first layer and every layer after that has a single internal perimeter of dark green "internal single extrusion". When I disable the internal single extrusion in process settings -> advanced -> Internal Thin Wall Type to either Gap fill or Perimeters Only the print works fine (albeit, with a hollow chimney)
Left: canceled print, right: gap fill
Am I missing something? This feels to me like it is extruding 2-10x as much as it should. The print slows down massively when it gets to the internal single extrusion and then creates a massive blob, and knocks the benchy off the build plate.
Banchy-6 factory / gcode has the issue (The Single Extrusion options, and perimeter overlap options don't really seem to affect the print very much at all, all massive over extrude.
The Benchy-7 prints fine with gap fill.
I was going to submit the factory files but they appear to be too large for this forum (5mb), and I don't have the patience to deal with that right now.
Thanks,
-Mike
