quad121
BLTOUCH v3 and Z Offset changing
I have just started using Simplify 3D and have noticed that I’m having to re-check and change the Z Offset before each print.
I never had this problem using Cura and never had to change the Z Offset before until I started using Simplify 3D.
Is there a setting I’m missing?
In the starting g-code I am using the same start up code as in Cura ( inc. g28 and g29)
