xSANTIAGO
Gaps for some top parts
Hello guys,
I'm experiencing some issues with my prints.
Pictures speak by themself. For some layers you can see gaps, but for the rest of the model the print is perfect.
Note : You can see where the gaps will appear on SPF3D.
I think it's a setting problem, i modified many things but nothing change.
Any idea ?
Thanks you for the help :)
For the first picture it's my fault (not enough infill) but for the rest, it shouldn't be like that
And now on the software
S3D-Alex
Re: Gaps for some top parts
Thanks for posting this! Could you please post a Factory File as well? We did have some changes occur to the Top Layer logic in 4.1.1 and 4.1.2 and how much overlap occurs so I would love to examine this more!
xSANTIAGO
S3D-Alex wrote: Thu Jul 30, 2020 9:20 am Thanks for posting this! Could you please post a Factory File as well? We did have some changes occur to the Top Layer logic in 4.1.1 and 4.1.2 and how much overlap occurs so I would love to examine this more!
Thank you for your answer, here is the .factory
fox.factory
(11.09 KiB) Downloaded 112 times
S3D-Alex
Thank you for the Factory File. It looks like the screenshot you included above may be from a different model than the fox though?
Either way I would suggest raising your current Infill Overlap % from 15% to 25% or 30%. This will help to make sure the solid fill layers bond well with your perimeters. Increasing your Infill Density % like you mentioned earlier would also help drastically with a large part like this.
