Hi, I would like to print the object on the snapshot.
I could set only one outer perimeter, this would probably works:
But is here a hidden feature or method to get a solid object using only outer perimeters?
It is basically made of walls. But the slicing les wholes between perimeters (Grid02), so in the end I have maby squares but not one only grid.
