using the G-Code Offsets on the G-Code tab to align each process
Yesss! that's just what I needed! I never look at the G-Code tab and now it holds the solution to my problem
Yes I know it works fine if I slice all the processes at once. I'ts definitely a bug and I can't find any rhyme or reason to it.
Anyway, that's great about the firmware too, I definitely need to install a custom FW for PID tuning and mesh bed leveling anyway but it's a bit of hassle. I'm not keen on using Linux
Until now I worked with an unsatisfactory workaround: Reducing the height of the coin base itself. But those are meant as trolley tokens and should fit as exact as possible. Or you could create various single layer processes and adjust the extrusion ratio, or adjust the bed everytime.
But your suggestion with the offset is a much better solution, I was not aware of that and will try it asap. I never look at the Gcode tab
I noticed S3D isn't really being developed anymore, so I'm not holding my breath for a bugfix, but at least S3D allows me to split models into different files at all.
Look at my coins, aren't they pretty? Altough the new coins with the circular infill from that factory file I posted look even better.
