You should be able to utilize a G1 command in your Starting Script to move the extruder to a different position. G1 allows for several parameters. X Y Z and F are most important, especially if this is the first movement command being issued. You will also want to make sure the machine has been homed (G28) prior to executing a G1, as otherwise the outcome is less predictable.
For more on common 3D printing G-Codes:
https://www.simplify3d.com/support/arti ... -tutorial/
For help in the Scripts tab:
viewtopic.php?f=8&t=1959
