using raft and first layers are killing me .. they are awful
... I tried so many things but just can't get bottom of the print to be ok .. tops are great, sides are great, overhangs are crap on this printer but that's not s3d's fault but crappy filament and even crappier hotend .. but bottoms are killing me
the overlap's are at maximum, extrusion is properly calibrated, measured to 5th decimal so that's not a problem, but even changing extrusion from 90 to 110 % does not solve the problem ... the bottoms layer fill don't go trough to the perimeter, it's underextruding it.. basically everything is wrong with it
.. whatever I change I can't make it work ...
Embed M117 codes into G-Code
open source and unlicence
