Shuggy wrote: ↑Thu Oct 08, 2020 1:59 pm
Hello,
I am looking for 3D printing filaments for that is resistant to automotive fuel systems.
Fuel lines are often manufactured with PTFE, but this is not readily available.
Please can you advise and Filament products that are available and resistance to Petrol / Gasoline?
Hugh
Hi Hugh!
Maybe there is a less expensive filament for that, but Fluorinar Kynar PVDF is rated resistant to Fuel/Diesel at up to 140 deg C. Depending on the type of PVDF it may drop to 110 deg C. I bought a roll (Fluorinar-C) from them but didn't print with it yet as I want to fully master PETG printing before that PVDF. Nozzle temp is between 250-260 deg C, and bet temp 110 deg C. Very high price though... 220 USD / 1kg.
You can have more information here on print settings and chemicals compatibility charts :
Fluorinar-H - 140 deg - Difficult to print, highly prone to warping, usually need to print bigger and machine to desired dimensions afterwards-
https://nilepolymers.com/fluorinar-kynar-filament/
Fluorinar-C - 110 deg - Easy to print, virtually no warping, printer dependent precision -
https://nilepolymers.com/fluorinar-c-kynar-filament/
Hope this helps!
