I'm nearly finished printing out all of the STL for a Trudgy Open RC car...outside of the chassis. I tried printing this on it's side but found the supports started to collapse and the whole thing was super brittle/fragile. What I really need to do with this is to print it flat on the bed. The dimensions for the chassis should fit on the print bed for FF Creator X, which is right around 155mm wide.
In S3D, however, the display bed is smaller than the object, as you can see in the screenshot above. The two chassis STL are driving me nutty, I can't seem to figure out how to print them out and doing it flat would offer the most support / solid print.
Any suggestions?
