Klippan wrote: ↑Thu Oct 15, 2020 2:42 am
Is there any easy way to get the coordinates of a specific point in the X-Y plane on the part to print?
You can also imagine moving a specific point on the part to a specific coordinate.
An "easy" way to get the exact point is using something simple as a 1mm x 1mm x 250mm box STL:
Box placed where I'd like to set start points. Dragging the box around using CTRL+LMB works well here.
Retracts aligned between back/sword (X/Y 115/85):
Don't forget to remove the box afterwards (or exclude it from the selected models list within the process).
Added something like this in a thread here:
viewtopic.php?f=23&t=5965&p=56749#p56749
(model:
https://www.thingiverse.com/thing:33804)
