for no reason today simplify 3d does not open. I took away my preferences, reinstalled the application, but it doesn't work. I uninstalled, reinstalled, but it doesn't work again.
I work in windows 10 with icore 9 and Nvidia Quadro Rtx 4000
If you're only getting a white window you might want to have a look at this thread:
Okay, so S3D seems to be really "stuck" when starting. Two things I'd recommend to check would be:
Ah, okay. You mentioned deleting the preferences, I wasn't sure what that applied to. Preferences/Settings are stored inside the Windows Registry. As far as I know S3Ds keys aren't removed when uninstalling, so maybe simply renaming the key and forcing S3D to do a "clean start" might be worth a try.feste wrote: ↑Fri Oct 30, 2020 1:08 pm the first option is not valid because I had deleted the whole folder. That's not it.
of the second link I didn't understand anything. Perhaps I could not enter the application the changes of a registry make changes to the application as well as if I applied them with the menu? But where are these registry?
Yes, doing manipulations inside the registry can have impacts as windows and installed programs do store quitefeste wrote: ↑Sat Oct 31, 2020 1:44 am I found what you indicated, but I didn't understand what to do. But does a person who uses software really have to do these things in order to use it? I liked the simplicity of Simplify3d... but if I have to do such operations it is not at all simple and - as far as I am told - it is also risky.
Check the update log to verify. Did you even read the thread I linked above?I think Windows has changed something. Am I the only one who has this problem?
