yes when you see strange slicing behavior and areas filled in that arent supposed to be like in the first two circled item then 99% of the time its a problem with the model.
When this happens, usually a "reverse face" will fix the issue. If it doesn't, reverse the face in the desgn software. If manifold is verified, then filp an adjacent face and flip it back.
