I printed objects with a single extruder without problems But now that I am trying to use 2 extruders I am having problems
I am trying to print with the right head and use HIPS in the left head ,
I am using a Makerbot replicator 2x
I have the Simpliying 3d software with the firmware config set to Makerbot/sailfish firmware ,
The model is a superhero model standing which needs support material
I have 1 process , both extruders set to ABS , left extruder set with supports turned on ,both extruders temp is 230c and build platform is set to 110c
selected profile is makerbot replicator 2x (Both extruders).
so I should be set to go .
I prepare print and go to preview mode , BUT if only previews the Support not the model ???? is this normal ?
go I send it to the printer and The printer only heats the right nozzle and tries to start a print
But it fails because the Build plate is cold !
Both the build plate and left nozzle are not being heated ? only the right nozzle is heated?
am I missing something?
I can get this to work with Makerware soft ware But it has a slicing error which leave a seam on everything I print and that's why I brought Simplify 3d
But so far Simplify 3d has been anything but simple lol
any help would be great thanks sen
