askabbs
A hole in the infill
Hello, I have the following problem:
I created a small box with a 1.3mm side wall. When I slice the STL file with ew = auto, the object has a hole in the sidewall in the fill and that over the entire height. The wall thickness is 1.3mm for the whole object.
How can I get rid of this problem!
Thank you very much in advance.
S3D-Alex
Re: A hole in the infill
Can you please post a Factory File so we can look into this?
