Hi everyone
I'm using S3D already for years by now. Every once in a while you get problems to achieve correct GCodes
I’m using one of my selfmade printers working with Duet 2 Wifi.
The attached STL file I cannot slice so that i get it run.
The original File comes from a guy who sells 3D-planes to print.
He says that only Cura can slice this file to get the correct GCode.
Do you have an idea where the problem ist o be located? Can you get it sliced an get a GCode?
I tried now for over 2 days but no result.
I would appriciate if you can help me out.
And great thank you for your efforts.
Martin
