For the older, I've used it since almost 2 years and appart from the usual issues like some clogging in the hot end no serious problems.
Suddenly one day the extruder stopped working during a print and then has never worked any more. Motor tested and it works and cable tested and works too. The only answers I found on the net are just users that forget to preheat the nozzle and didn't know there was a security to prevent motor forcing non-melted plastic to move through the nozzle. Have you an idea what can I do ? Do I have to bought a new motherboard?
The problem on the other ender 3 is sever under-extrusion. G-code is not the problem, I could perfectly do some print on the other with the same and I tried with an other motor and it's still not working propely. Any one has an idea ? Do I need to change the motherboard on this one too?
Thank you for your futur answers
