jconelias
XYZprinting Da Vinci Pro Wifi bug
When I attempt to print a file to my printer over wifi everything works fine up until the first layer finishes and the printer crashes. But what is weird is if I print the same exact file over USB same settings and all it runs smoothly. Have tried different computers(Mac and Windows), networks, etc, what puzzles me is the print starts but after approximately the first layer finishes the Davinci Screen freezes, the alarm sounds, and I'm forced to power cycle it.
Not sure where to take it from here. Any Thoughts?
XYZprinting Da Vinci 1.0 Pro.fff
(11.64 KiB) Downloaded 110 times
Re: XYZprinting Da Vinci Pro Wifi bug
I can't think of why this would happen. The Wifi method of printing on this machine uploads the entire file before beginning the print so it shouldn't be an issue with the connection to the printer. Are you disconnecting from the printer after the file upload completes and the print begins? If not, please try that. You can disconnect by clicking disconnect in the Tools > Machine Control Panel or by closing Simplify3D.
jconelias
Ok yes, that fixed the problem thank you!
