Hi there,
I use a small motor to drive window the blinds in our home. The only problem I have is the motor coupling. The printed hole which takes the motor shaft is not really vertically printed, so it ends up in a wobbling movement.
Is there anything I can do to improve the print result?
Motor + Connector
