Summarized Info
Auto-Level Running but generated mesh not appearing to be utilized (causing large z-axis print variations)
Z-Offset was calibrated and set in the printer's firmware, not in S3D nor in Cura
Starting code used in Cura that works:
G28 ;home
G90 ;absolute positioning
M280 P0 S160 ; BLTouch alarm release
G4 P100 ; delay for BLTouch
G28 ; home
G29 ; auto bed leveling
G1 X0 Y0 Z15 E0 F300 ;go to wait position
M140 S60 ;set bed temp
M109 S200 ;set extruder temp and wait
G1 Z0.8 F200 ;set extruder height
G1 X220 Y0 E80 F1000 ;purge line
;end of start scriptCode: Select all
G90
M82
M106 S0
G28 ; home all axes
G28 ; home
M205 X10 Y10 ; set XY jerk to 10
M163 S0 P1.0
M163 S1 P0.0
M164 S0 ; set T0 mixing ratio to full right
M163 S0 P0.0
M163 S1 P1.0
M164 S1 ; set T1 mixing ratio to full left
M163 S0 P0.5
M163 S1 P0.5
M164 S2 ; set T2 mixing ratio to even mix
T0 ; select full right extruder
G1 X15 Y10 Z0.3 F3000 ; avoid binder clips
M140 S60 T0
M190 S60 T0
M104 S200 T0
M104 S200 T1
M109 S200 T0
M109 S200 T1
G1 X195 E15 F500 ; prime line
G1 X205 F100 ; slow wipeImage of failed purge line also attached (thicker line on left and thinner on right as nozzle goes into bed without utilizing mesh to compensate)
