Hi ,
i have a printer with 3 tool heads so i made a profile where there is 3 extruders, each with it's own toolhead index number (from 0 to 2)
and i want to print with the third one and only this one.
so i open the process select the extruder LGX FF which got index 2 do ok and slice.
but when i save the gcode the tool used it the T0, always T0
i even tried to set 3 processes and select one extruder on each process but the problem remains.
even if i use the process 3 which is bound to the extruder index 2 the tool selected is always T0
Worse sometimes i cannot change some values on some processes and i can on others.
