JD95
Retraction not done between "islands" of support
I'm finding that the machine isn't retracting when moving between different areas of support material. This is causing blobs to show up on the part when the machine traverses between these support material areas. Is there a setting I'm missing? If there is, I haven't found it yet.
JD95
Re: Retraction not done between "islands" of support
After more careful re-examination, the machine does retract for support, it didn't look like the shaft was turning, but it was. I apologize for the mistaken problem report.
