uzora
Scaling Factor Settings
With the ABS models I print, I always scale in the X/Y direction which makes up for the shrinkage. I use the Hoziontal Size Compensation setting to adjust my vertical hole sizes. A little back and forth testing and minor adjustments between the two gives me excellent dimensional results. So these two constants always remain the same with a particular brand of filament I use. Temperatures, speed etc also always remain the same.
So I have a saved profile with my desired settings, but it appears to me I always have to enter the scaling factor into each model I import (unless I group them) each and every new model.
Am I missing something here or is there a way to save the desired scaling factor so I don't have to reapply it to every model(s) I import.
I have been known to forgot to scale my imported models on more than one occasion, but that's on me.
