I have noticed 2 problems that are bugging me.
- The first one was the delta build volume as discussed in this thread
viewtopic.php?t=1807&sid=18ec754c6b09e7 ... 91e1575175
it seems it has been this way since v2.22
Basically I have to tell it the machine is a certain size so that I can get the correct visual display of the workspace. "multiple by 0.707"
The problem is if I then need to auto arrange it wont let me. I can load a printer model so that i can see the correct workspace and tell it the workspace is actually larger but this is a crappy workaround.
Surely enough people are using delta printers that the issue would be worth fixing.
i have attached screenshots of my slice. The printer diameter is 387mm
- The second issue is with shelled we use to make molds the support shows up on the other face also.
Screenshot attached
