johnathansmith1969
Temperature on Monoprice Maker Select Plus is not setting right!
if you look at my settings below I have it set to 200 but the printer is only going to 190... I tested this with cura and some others and it does goto 200
dibor
Re: Temperature on Monoprice Maker Select Plus is not setting right!
Hi.
U show bed temp. settings.
Add or choose temperature controller.
Choose extruder and set temperature.
rhawley88
are you using a custom start script?
