mushoo
[ADDED] Dual Extruder Skirting
Would be great to be able to set this up - I use the skirt at the start to make sure that ooze is cleared (often it means the first few extrude moves are 'empty') but I can only define the skirt for the primary extruder. If I could do primary at 5mm offset, and the secondary extruder at 8-10mm offset, that would be awesome.
It'd also be useful as a 'wipe' on every layer - skirt and model in one pass, then secondary skirt and supports in the next pass, per layer.
JD95
Re: Dual Extruder Skirting
I would like this too.
I'd also like a "wipe and prime" tower option. I'd like to see a hollow cylinder so it sticks better than a more compact solid square footprint another slicer uses for a tower.
Umpa
I think the dual print should be more like markerware. Dual printing in S3D sucks.
aschwehr
+1 on more second extruder control. It would be nice to be able to wipe the nozzle.
AK_Eric
+1 : using our 2x, we really need two skirts, one for each nozzle, to help wipe them at each layer: This would help buildup from cooking in the nozzle, and workslike a nice wipe wall.
Bots:
Makerbot Replicator 2x / Sailfish on Mightyboard
Custom C-Bot / RepRap Firmware on RADDS
Custom Tevo Little Monster / RepRap Firmware on Duet
joealarson
If S3D could get dual extrusion printing right (and implemented spurs) I would never have reason to go back to MakerWare.
BluePlexus
+1 on this feature. Having the skirts for both extruders would greatly help the dual color prints. Right now I try to print a calibration print with both to get them started and then have to quickly start the new one. Also feed/push both extruders instead of the primary one before printing so they are both ready.
LooserX
+1 on this feature
/LooserX
JFettig
I just assumed dual extrusion was already set up if they were advertising functionality I have a CHIMERA on the way and I'm printing a mount for my second cold end... definitely need proper dual extrusion so I can run HIPS supports!
jjlink
+1 on this feature.
Currently as a workaround I put another small sacrificial object to be printed before the real object. This way the small object gets the ooze wiped on it when it switches extruders rather than on the real object I want.
Felix 3.0 printer w/the Prometheus system, Eclipse3D v1.1 & v2.1, Moai SLA 3D printer.
