lmarkie74
PETG Printing
Where are these snot balls coming from and how do I get rid of them?
airscapes
Re: PETG Printing
lmarkie74 wrote: Wed Aug 31, 2022 2:47 pm Where are these snot balls coming from and how do I get rid of them?
Sinus, blow your nose!
Never had snot balls on my print jobs, just in my nose.
gwhite
Re: PETG Printing
I believe the technical term is "zits"... It tends to be worse with PETG than PLA.
Check out the trouble shooting guide: https://www.simplify3d.com/support/prin ... -and-zits/
Basically, you need to adjust your retraction settings. Different brands of filament, different temperatures, etc. can all require fine tuning things to get the cleanest possible prints.
EchoAlpha
Re: PETG Printing
Hard to say without pictures. In my experience, PETG doesn't handle over-extrusion well, so it is better to err on the side of under-extrusion.
Re: PETG Printing
If you mean that filament collects on the nozzle tip then that is a sign that you might be over extruding a bit. This is well known issue with PETG. Drop your extrusion multiplier a tad and see how it goes.
KOPrinting
Re: PETG Printing
As the other users pointed out, hard to judge without pictures. Along with the advice given above, I would just add that PET-G is pretty hygroscopic and not drying it before a print can also cause issues.
