HeinrichBe
Width of infill lines
I often have to print honeycombs of ceramic. At the moment I do some perimeter walls. And inside the form I use the infill feature "full honeycomb" to create the honeycomb structure. Using a standard stl of a honeycomb never works. S3D always tries to create ver ylittel boxes one by one. But with honeycomb infill it works nearly perfect. My question is: Is there a feature in S3D to make the lines of the infill smaller. At the end the width of these lines is teh thickness of my honeycomb walls.
Re: Width of infill lines
You can set the infill extrusion width % in the Infill tab.
HeinrichBe
Thanks it works great.
