paboman
Gcode problem..please help
im having trouble getting my delta to work properly with your new software.
after the print start the first line of gcode move the delta arm in a position that cant be while in home. I hear the steppers loosing steps. (than all is offsetted and i have to abort)
this line generate the error and removing it manually from the gcode permits me to have the print done.
Code: Select all
G0 X11.117 Y-0.03 F4800
first part of my gcode
Code: Select all
; G-Code generated by Simplify3D(TM) Version 2.1.2
; nov 12, 2014 at 5:20:22
; Settings Summary
;   processName,delta pla
;   applyToModels,pen clip
;   printMaterial,PLA
;   printQuality,High
;   extruderName,Extruder 0.35
;   extruderToolheadNumber,0
;   extruderDiameter,0.35
;   extruderAutoWidth,0
;   extruderWidth,0.35
;   extrusionMultiplier,0.9
;   extruderUseRetract,1
;   extruderRetractionDistance,1
;   extruderExtraRestartDistance,0
;   extruderRetractionZLift,0
;   extruderRetractionSpeed,1800
;   extruderUseCoasting,0
;   extruderCoastingDistance,0.2
;   extruderUseWipe,0
;   extruderWipeDistance,5
;   primaryExtruder,0
;   layerHeight,0.2
;   topSolidLayers,4
;   bottomSolidLayers,4
;   perimeterOutlines,2
;   printPerimetersInsideOut,1
;   startPointOption,2
;   startPointOriginX,0
;   startPointOriginY,0
;   startPointOriginZ,300
;   sequentialIslands,0
;   spiralVaseMode,0
;   firstLayerHeightRatio,0.9
;   firstLayerUnderspeed,0.5
;   useRaft,0
;   raftLayers,3
;   raftOffset,3
;   raftSeparationDistance,0.14
;   raftInfill,85
;   disableRaftBaseLayers,0
;   useSkirt,1
;   skirtLayers,2
;   skirtOutlines,2
;   skirtOffset,4
;   infillExtruder,0
;   externalInfillPattern,Rectilinear
;   infillPercentage,20
;   outlineOverlapPercentage,15
;   minInfillLength,5
;   infillLayerInterval,1
;   randomInfillStartPoint,1
;   infillAngles,45,-45
;   generateSupport,1
;   supportExtruder,0
;   supportInfill,40
;   supportExtraInflation,0
;   supportLayerInterval,1
;   supportHorizontalPartOffset,0.3
;   supportUpperSeparationLayers,1
;   supportLowerSeparationLayers,1
;   supportGridSpacing,4
;   maxOverhangAngle,45
;   supportAngles,0
;   temperatureName,Extruder 1 Temperature,Heated Bed
;   temperatureNumber,0,0
;   temperatureSetpointCount,1,1
;   temperatureSetpointLayers,1,1
;   temperatureSetpointTemperatures,205,50
;   temperatureStabilizeAtStartup,1,1
;   temperatureHeatedBed,0,1
;   temperatureRelayBetweenLayers,0,0
;   temperatureRelayBetweenLoops,0,0
;   fanLayers,1,2
;   fanSpeeds,0,100
;   blipFanToFullPower,0
;   adjustSpeedForCooling,1
;   minSpeedLayerTime,15
;   minCoolingSpeedSlowdown,20
;   increaseFanForCooling,0
;   minFanLayerTime,45
;   maxCoolingFanSpeed,100
;   increaseFanForBridging,0
;   bridgingFanSpeed,100
;   use5D,1
;   relativeEdistances,0
;   allowEaxisZeroing,1
;   includeM10123,0
;   stickySupport,1
;   detectArcs,0
;   arcReplaceG2G3,0
;   arcRadialCompensation,1
;   gcodeXoffset,0
;   gcodeYoffset,0
;   gcodeZoffset,0
;   overrideMachineDefinition,0
;   machineTypeOverride,1
;   strokeXoverride,200
;   strokeYoverride,200
;   strokeZoverride,400
;   originOffsetXoverride,100
;   originOffsetYoverride,100
;   originOffsetZoverride,0
;   homeXdirOverride,0
;   homeYdirOverride,0
;   homeZdirOverride,1
;   flipXoverride,1
;   flipYoverride,-1
;   flipZoverride,1
;   startingGcode,G28 ; home all axes
;   layerChangeGcode,
;   toolChangeGcode,
;   endingGcode,M104 S0 ; turn off extruder,M140 S0 ; turn off bed,M84 ; disable motors
;   createX3G,0
;   celebration,0
;   celebrationSong,Random Song
;   postProcessing,
;   defaultSpeed,3600
;   outlineUnderspeed,0.5
;   supportUnderspeed,0.8
;   rapidXYspeed,4800
;   rapidZspeed,1000
;   minBridgingArea,50
;   bridgingExtrusionMultiplier,1
;   bridgingSpeedMultiplier,1
;   filamentDiameter,1.75
;   filamentPricePerKg,46
;   useMinPrintHeight,0
;   minPrintHeight,0
;   useMaxPrintHeight,0
;   maxPrintHeight,0
;   overlapRemoval,0
;   overlapRemovalPercentage,0.3
;   useDiaphragm,0
;   diaphragmLayerInterval,20
;   robustSlicing,1
;   mergeAllIntoSolid,0
;   onlyRetractWhenCrossingOutline,1
;   retractBetweenLayers,1
;   useRetractionMinTravel,0
;   retractionMinTravel,3
;   useRetractionOozeRate,0
;   retractionOozeRate,100
;   onlyWipeOutlines,1
G90 ; use absolute coordinates
M82 ; absolute extrusion distances
G21 ; set units to millimeters
M106 S0
M140 S50
M190 S50
M104 S205 T0
M109 S205 T0
G28 ; home all axes
G92 E0
G1 E-1 F1800
; layer 1, Z = 0.18
T0
; tool H0.2 W0.35
G0 Z0.18 F1000
G1 E0 F540
G92 E0
G1 X11.12 Y0.088 E0.0031 F1800
G1 X11.127 Y0.163 E0.0051
G1 X11.165 Y0.382 E0.0109
G1 X11.184 Y0.45 E0.0127
G1 X11.208 Y0.516 E0.0146
G1 X11.321 Y0.751 E0.0214
G1 X11.334 Y0.773 E0.0221
G1 X11.491 Y0.982 E0.0289
G1 X11.508 Y1.001 E0.0296
G1 X11.7 Y1.174 E0.0364
G1 X11.758 Y1.217 E0.0382
G1 X11.817 Y1.254 E0.0401
G1 X12.011 Y1.35 E0.0457
G1 X12.173 Y1.408 E0.0502
G1 X12.27 Y1.43 E0.0529
G1 X12.525 Y1.464 E0.0596
G1 X12.623 Y1.467 E0.0622
G1 X12.839 Y1.448 E0.0678
G1 X12.864 Y1.444 E0.0685
G1 X13.119 Y1.37 E0.0755
G1 X13.94 Y1.047 E0.0986
G1 X15.474 Y0.853 E0.1391
G1 X17.208 Y1.251 E0.1857
G1 X18.585 Y2.147 E0.2287
G1 X19.434 Y3.15 E0.2631
G1 X20.027 Y4.323 E0.2976
G1 X20.508 Y7.03 E0.3695
G1 X7.731 Y24.841 E0.9437
G1 X7.24 Y25.427 E0.9637
G1 X6.499 Y26.158 E0.991
G1 X5.683 Y26.797 E1.0181
G1 X4.998 Y27.236 E1.0394
G1 X4.071 Y27.712 E1.0667
G1 X3.056 Y28.095 E1.0952
G1 X2.046 Y28.35 E1.1224
G1 X1.289 Y28.466 E1.1425
G1 X0.568 Y28.521 E1.1614
G1 X-13.64 Y28.525 E1.5336
why the software is adding that line ?!
and why it calculate that moves if the printer cant do it ?!?
many thanks
pabo
KeyboardWarrior
Re: Gcode problem..please help
G0 X11 Y-0.03 F4800 is simply to move 11 mm to the right and .03 mm downward (delta printers usually have the bed origin at the middle of the build plate) This is where I would guess the start of your raft/skirt or shell of your part starts depending on your settings. I don't know how that this line in particular could be causing the issue.
dhylands
If you're losing steps, then your firmware may be trying to accelerate too quickly, or it may simply be trying to move faster than your mechanicals can move.
You could try lowering the feed rate (the F4800) 4800 mm/min corresponds to 80 mm/sec
