goaty_rn
Update Firmware Configuration
The Update Firmware Configuration which appeared under g-code in v4 is missing in v5 or I cannot find it. I need to use RepRap as my FW type - anyone know where to set it?
Re: Update Firmware Configuration
The firmware type is set slightly differently in V5. Just select G-Code as the Export File Format on the Output tab and it will use the RepRap/Marlin/Klipper style firmware commands automatically.
