These two footers were generated by the same factory file - one in V4.1.2, the other in V5
Not sure what's up with the build time estimate.
What prompted me to look at the footer was a file I'm running on a Duet2Wifi-based machine is not displaying a filament usage estimate.
DWC is looking for the "Filament length:" string - and I also discovered that on this one it is case sensitive. Length does not work. length does.
V4.1.2:
; **** end of end.gcode ****
; Build Summary
; Build time: 6 hours 31 minutes
; Filament length: 93838.3 mm (93.84 m)
; Plastic volume: 225707.51 mm^3 (225.71 cc)
; Plastic weight: 243.76 g (0.54 lb)
; Material cost: 15.60
V5
; Build Summary
; Build Time: 335483040 hours -2147483648 minutes
; Material Length: 91672.6 mm (91.67 m)
; Material Volume: 220498.4 mm^3 (220.50 cc)
; Material Weight: 238.14 g (0.53 lb)
; Material Cost: 15.24
