OK simplify 3d has had a bug since day 1. it loves printing in "mid air" when it should easily be smart enough to not do this.
see my pictures and factory file. if you try to print a cylinder on top of a cube it does NOT print a solid layer between the two objects which is NEEDED when using "low infill" settings.
S3D's answer was to use more infill which is just dumb as it wastes time and plastic for models that do not require this.
the only real solution was to use multi process to FORCE it to print a solid layer at the interface. and even that can require work arounds to forces s3d to do what you want.
now we have dense infill. PERFECT exactly what we need. it seems the "interface" and increases the infill density as I define it. SO PERFECT. except..... it completely fails. IT LEAVES THE STINKING HOLE !!!! the one thing it needs to remove (the hole) it refuses to remove !!! and now the normal work around ALSO fails (create 3 solid layers but now it prints 1 solid 1 fill 1 solid BREAKING the work around)
the "dense infill" needs to cross THE ENTIRE PLANAR SURFACE !!!! filling the "hole" at the interface "IS" the reason to use this feature.
which I can use annoying wasteful multi process to fix this on SIMPLE models. just you TRY and do this on a complex numbers model say with "stair steps" that would require you do this is dozens or more times to where you finally give up and BLOW kilo's of plastic to just increase the infill all over to avoid failures.
File 0 is the object in question.
File 01 is what S3d DOES (wrong. it LEAVES the stinking HOLE in the center)
File 02 is what is "SHOULD" do (in reality this should create the NUMBER of dense layers I specify before and AFTER the interface PLUS the number of layers for top and bottom. SO if I specify 3 dense layers on a model with 3 top and bottom layers it should create 9 dense layers. 3 before 3 during and 3 after the inferface for maximum integrity and minumum filament usage.
you need a solid monolith structure to transition or the part is weak at the interface
When I use solid diaphram and process trick to add 3 solid layers instead of does what you see in image 4
it makes 1 solid one with a hole and another solid. Grrrr WTAF is up with that??
PLEASE FIX this setting could SO easily fix this problem ENTIRELY if it did not leave the HOLE in the dense layers.
