Advall
Limited Global G code Offset issue
Max offset one can enter is 99.99 mm.
So how can I print say only the top 25 mm of a item that is say 200 mm high when max global g code offset is 99.99 mm?
Maybe there is a different way?
Any suggestions are very welcome.
Re: Limited Global G code Offset issue
You should not use the gcode offsets for that. Instead, click the Custom Zones button at the bottom and enable the "Start printing at Z height" option.
