Mogal
Connecting to DUET 2 WiFi?
Anyone successful connecting directly to a duet?
I can't seem to figure it out.
Thanks.
Stout
Re: Connecting to DUET 2 WiFi?
There does not seem to be a direct link to Duet cards :? At least SDJake wrote that in a thread I can't find.
I use several different Duet3D cards in my printers and it's a NoNo for me to upgrade to v5 when Prusa and other slicers handle it so smoothly.
Edt:
Found it....
S3D-Jason wrote: ↑Sat Dec 17, 2022 4:02 pm I don't think the Duet board was listed as one of the supported Wifi printers on the release notes, so I'm guessing there's just new code required to support that board. The team is very open to feature requests right now, so certainly vote for it on the Feature Request subforum if you want to see it added!
joel
As far as I have gotten is when testing the connection over wifi, it seems to connect but then errors out saying javascript needs to be enabled.
joel wrote: ↑Sun Dec 18, 2022 8:02 pm but then errors out saying javascript needs to be enabled.
Would you mind posting a screenshot of this error? I'm not sure it's one we have seen before.
joel
Here is the spew I get, this is running 3.4.5 on the duet. The failure shows up on each attempt,
We're sorry but Duet Web Control does not work properly without JavaScript enabled. Please enable it to continue
Attempting connection at 192.168.1.69:3000...
Connection refused. Make sure the device is turned on and the connection details are correct.
SENT: GET http://192.168.1.69/command GETPRINTERSTATUS
SENT: GET http://192.168.1.69/api/v1/system
READ: <!DOCTYPE html><html lang="en" translate="no"><head><meta charset="utf-8"><meta http-equiv="X-UA-Compatible" content="IE=edge"><meta name="viewport" content="width=device-width,initial-scale=1,user-scalable=0"><meta name="google" content="notranslate"><!--[if IE]><link rel="icon" href="/favicon.ico"><![endif]--><title>Duet Web Control</title><link href="/css/app.23e90265.css" rel="preload" as="style"><link href="/js/app.d0ad7b20.js" rel="preload" as="script"><link href="/css/app.23e90265.css" rel="stylesheet"><link rel="icon" type="image/png" sizes="32x32" href="/img/icons/favicon-32x32.png"><link rel="icon" type="image/png" sizes="16x16" href="/img/icons/favicon-16x16.png"><link rel="manifest" href="/manifest.json"><meta name="theme-color" content="#2196f3"><meta name="apple-mobile-web-app-capable" content="yes"><meta name="apple-mobile-web-app-status-bar-style" content="black"><meta name="apple-mobile-web-app-title" content="Duet Web Control"><link rel="apple-touch-icon" href="/img/icons/apple-touch-icon-152x152.png"><link rel="mask-icon" href="/img/icons/safari-pinned-tab.svg" color="#2196f3"><meta name="msapplication-TileImage" content="/img/icons/msapplication-icon-144x144.png"><meta name="msapplication-TileColor" content="#000000"></head><body><noscript><strong>We're sorry but Duet Web Control does not work properly without JavaScript enabled. Please enable it to continue.</strong></noscript><div id="app"></div><script src="/js/app.d0ad7b20.js"></script></body></html>
Connection failed.
Mogal
I get the same/similar error.
Attempting connection at 192.168.68.68:3000...
Connection failed.
SENT: GET http://192.168.68.68/command GETPRINTERSTATUS
SENT: GET http://192.168.68.68/api/v1/system
READ: <!DOCTYPE html><html lang="en"><head><meta charset="utf-8"><meta http-equiv="X-UA-Compatible" content="IE=edge"><meta name="viewport" content="width=device-width,initial-scale=1,user-scalable=0"><!--[if IE]><link rel="icon" href="/favicon.ico"><![endif]--><title>Duet Web Control</title><link href="/css/app.e2701cec.css" rel="preload" as="style"><link href="/js/app.56671d18.js" rel="preload" as="script"><link href="/css/app.e2701cec.css" rel="stylesheet"><link rel="icon" type="image/png" sizes="32x32" href="/img/icons/favicon-32x32.png"><link rel="icon" type="image/png" sizes="16x16" href="/img/icons/favicon-16x16.png"><link rel="manifest" href="/manifest.json"><meta name="theme-color" content="#2196f3"><meta name="apple-mobile-web-app-capable" content="yes"><meta name="apple-mobile-web-app-status-bar-style" content="black"><meta name="apple-mobile-web-app-title" content="Duet Web Control"><link rel="apple-touch-icon" href="/img/icons/apple-touch-icon-152x152.png"><link rel="mask-icon" href="/img/icons/safari-pinned-tab.svg" color="#2196f3"><meta name="msapplication-TileImage" content="/img/icons/msapplication-icon-144x144.png"><meta name="msapplication-TileColor" content="#000000"></head><body><noscript><strong>We're sorry but Duet Web Control does not work properly without JavaScript enabled. Please enable it to continue.</strong></noscript><div id="app"></div><script src="/js/app.56671d18.js"></script></body></html>
Connection failed.
Oh, I think that is actually a javascript message being sent by the Duet board. It's trying to display a webpage that says "We're sorry but Duet Web Control does not work properly without JavaScript enabled. Please enable it to continue."
That's a pretty confusing message. I'm not sure why javascript would be required to do a simple http GET command...
tooponn
hellodear.in
tea tv apk
dmbgo
Any solutions for this?
dindo59
hello, i have the same problem, simplify 5.1.1 , duet2 wifi , connection doesnt work, PLEASE can FIX ? can help US ? thank you
