S3D v5
Whenever I doubleclick an STL/OBJ/.factory/.gcode (currently associated to S3D), S3D opens....but crashes with a Segmentation Fault 11.
If I open manually S3D then File->Open the files, it works fine.
I store Simplify3D folder INSIDE a folder which is INSIDE the Applications folder, if that helps troubleshooting.
