bolsoncerrado
Simplify3D Crashes when ran outside the Applications folder (macOS)
S3D v5
Whenever I doubleclick an STL/OBJ/.factory/.gcode (currently associated to S3D), S3D opens....but crashes with a Segmentation Fault 11.
If I open manually S3D then File->Open the files, it works fine.
I store Simplify3D folder INSIDE a folder which is INSIDE the Applications folder, if that helps troubleshooting.
Re: Simplify3D Crashes when ran outside the Applications folder (macOS)
If you install the software in the default location (/Applications/Simplify3D-5.0.0), does the crash stop happening?
bolsoncerrado
Why don't you as S3D try to install the app on a folder and let me know if it works? In the end you don't force the installation in a specific folder right?
bolsoncerrado
Looks like an un handled permission:
bolsoncerrado
Further on this, on a Mac M1 with Ventura, when I doubleclick an STL, S3D opens and (finally!) stays open, but the STL is NOT loaded.
