3dbybrunolopes
[FIXED] Part being filled in
Anyone has a explanation to this...?!?!?!?!?
In S3D v4, working as expected, but in S3D v5, does this?
Re: Part being filled in
Are you able to share the factory file?
3dbybrunolopes
Yes...for some reason...now is slicing correctly...but with this one is doing it again. Attached
RAFA_Insert_Preto_2.factory
(182.75 KiB) Downloaded 236 times
3dbybrunolopes
Check this video I've made
https://we.tl/t-aZEDLirSyD
S3D-Jason wrote: ↑Tue Dec 20, 2022 6:21 pm Are you able to share the factory file?
I was working on this part also. I can fix the top being filled in by changing the layer height from 0.2000 to 0.2001. Seen this before once in a while.
However, the sidewalls are bad, see picture.
On this if I remove G90 OR uncheck "use relative extrusion distances" the side walls are ok. I should not have to do that though.
I can load this model on another printer and it is fine.
This all works fine in V4.
3dbybrunolopes
Jason,
Please have a look at this video I've made...I think these slicing issues are related to manual transformations
VIDEO: https://we.tl/t-aZEDLirSyD
3dbybrunolopes
uppp
Beevo
I am seeing the exact same issue. Parts previously printed with version 4 are now hollow!
I looked through the setting but can't see anything to change to cure this.
Cat_Defense_Keychain PETG 3X.gcode
(1.28 MiB) Downloaded 374 times
Beevo
I guess I have to go back to version 4 which works, as I can't seem to get any help fixing this bug in version 5...
How do I get a refund for the update I purchased?
Or even better, how about some help with a solution to the problem I am having?
Beevo
gearsawe
post the Cat STL file. or are you opening this directly from the V4 Factory file?
found an image of the file on a site but get a 404 not found https://stlbase.com/browse/cat+self+defense+keychain/
without the STL or factory file we cant help you. welcome to PM me if you do not wish to post it here.
