festus01
Version 5, G-Code error with CraftBot
with Version5 generated g-code files does not work with CraftBot plus printer.
I got a error "invalid item for M106:P"
With version 4.1.2 it works fine.
I'm also missing the Firmware Configuration tool.
Re: Version 5, G-Code error with CraftBot
Try adding the following to your post processing script
{REPLACE " P0\n" "\n"}
That should remove the P0 parameter that Craftbot doesn't seem to know how to handle
festus01
S3D Jason,
thanks for your solution.
Now it works, and I can go ahead with version 5.
bdegen
I have the same problem with the Craftbot plus printer. In which of the 7 script windows does this command have to be entered? Do the curly brackets have to be added or not?
Place it in the "Post Processing" script. And yes, you need to include the curly braces.
