billyd
Z Hop
Please make Z hop independent of retractions and connect it to travel moves instead
siemslikelynn
Re: Z Hop
Agreed
gearsawe
Re: Z Hop
usual you are retracting and then moving with a Z Hop. When would you Z hop without a retract?
personally I like where it is now, as the 2 really go hand in hand.
billyd
Re: Z Hop
gearsawe wrote: ↑Sat Dec 24, 2022 11:56 am usual you are retracting and then moving with a Z Hop. When would you Z hop without a retract?
For some materials it is best to disable retractions entirely, but would still like to hop during fast travel. Also even when you want retractions there are sometimes instances where a retraction isn't performed but a fast travel is, and you may want Z hop during any fast travel.
gearsawe
Re: Z Hop
billyd wrote: ↑Sat Dec 24, 2022 12:24 pm
So like you said. Sounds like it should stay where it is. you might disable retraction then have Z Hop and the reverse. You can see them both in the same place since they both go hand in hand.
billyd
Re: Z Hop
gearsawe wrote: ↑Sun Dec 25, 2022 5:07 pm
No because there are times when your retractions don't immediately come before a fast travel (when you are using retractions in your model). And I use Z hop to avoid knocking parts over on the build bed, for me it has nothing to do with retractions. I want zhop to precede all fast travel moves (when I want Zhop). I DON"T want zhop to occur for every retraction as it's often not needed for every location you retract.
