DanceM
No checkmark to hide the objects in V5
There is no checkmark to hide the objects in V5.
nerys
Re: No checkmark to hide the objects in V5
yep. i used that a lot and they also munged up groupings since hiding an object DOES NOT stop the process from slicing it (which it should)
now it takes extra clicks when I print it ALWAYS highlights the whole group and I don't WANT to highlight the whole group so now I have to click select NONE and then select the one process I want to print. Grrrr
Uncle Jessy
Also use this one a lot and hope it gets added back in. Great when importing lots of files
bolsoncerrado
+1 to bring it back!
Can't believe the vast amount of stuff they removed that was superuseful!!
I'm starting to regret on the upgrade damnit!
gearsawe
+1
bring back. kind of looks like there is a space for it. looks more like an oops bug.
gearsawe
is this counted as a feature if it is removed? HA!
DrD
Uncle Jessy wrote: Fri Dec 16, 2022 8:42 pm Also use this one a lot and hope it gets added back in. Great when importing lots of files
I too used that feature all of the time. For now, you can "replicate" the functionality by grouping your models
and moving them off the print bed. Then slice as normal. S3D will complain about models being off the build
surface but it's ok to ignore the warning.
dsiegfried
This one is easy. Go into Edit Process Settings, click on Select Models, then select only the models you want to slice.
