Your print has a lot of issiues, but the problem you ate talking about is ghosting, your printer is vibrating. You can reduce the speed or acceleration or you can make the printer more sturdy
yep..not slicer coding issue...that's a hardware settings issue. Acceleration is too high, belts are too loose, or trying to print too fast. You have to find the balance for your machines capabilities
ptegler
