danielhenley
Adaptive Layer thickness should adjust top/bottom layer count
I love the new adaptive layer thickness feature, although there one annoying issue: the top and bottom layer count don't adaptively adjust as well.
This results in top/bottom surfaces on parts that can be too thick or too thin depending on what the adaptive process is doing.
This is a problem because in order to get quality top surfaces at 0.1mm layer count I typically use 12 layers, but this results in wasteful, extra thick top surfaces when the slicer adapts to 0.3mm layer height.
RetroDesign3D
Re: Adaptive Layer thickness should adjust top/bottom layer count
+1 if this is a toggle-able setting. I can think of cases where I would want adaptive but not to adjust top layers
