CreatorX
Wifi connection issue with Raise3D Pro2
Bonjour,
Mon imprimante Raise Pro2 n'est pas détectée avec l'assistant de connexion de Simplify5.
J'ai testé avec le recherche automatique et avec l'adresse IP de l'imprimante, avec différents ports, Simplify est bien déclaré dans le par feux windows 7 , mais l'imprimante n'est pas détectée.
Pourtant avec Ideamaker la connexion fonctionne.
Avez-vous réussi à connecter une imprimante Raise3D en Wifi svp ?
Merci
I try In English ! :
Bonjour
My Raise Pro2 printer is not detected with Simplify5 connection Wizard.
I tested with automatic search and with IP address of the printer, with different ports, Simplify is ok in the windows 7 firwall, but the printer is not detected.
However with Ideamaker the connection works.
Have you managed to connect a Raise3D printer via Wifi please?
Merci
CreatorX
Re: Wifi connection issue with Raise3D Pro2
Answer from Software technical support :
"Thank you for your request. I would be glad to forward support for the Raise3D WiFi as a feature request to the development team. I am sure they will evaluate this request along with many others for the future releases. "
Seems that Simplify5 does not support Raise3D printers wifi connection :|
CreatorX
Version 5.0.2, connection still not working ...
Someone here using Raise3D printers whith Simplify ?
CreatorX
I think that the compatibility of Raise3D printers will never be implemented by simplify3D. :cry: :|
A workaround :
- Create a Gcode file with ideamaker with the same orientation and layer thickness that you used in Simplify3D.
Ideamaker creates a Gcode file and a ".data" file.
- Upload with Ideamaker the gcode file created by simplify with the ".data" file from Ideamaker in the same directory.
You will have on the Raise3D printer the display of the drawing and the printing time.
It looks like you have 2 threads for the same issue, so please feel free to continue the discussion here:
viewtopic.php?t=17102
That will be a better place for us to track how many other users are also interested in this feature.
